2 column bug in review mode and sync issue on iphone
Two bugs
  1. on sorting with document location in review flashcard mode, mn3 does not recognize two column formatting of pdf. So the sort is incorrect.
  2. Sync issue on iphone 6s plus latest ios.
The review cards just show fetching data from icloud and never changes to database synced. The sync does happen but some part is missed. This seems to be happening only on my iphone. Ipad and mac syncs are working perfect
For the first problem, could you please send us your PDF we will try to solve the problem.
For the second problem, note data is slower to sync at the moment due to fragmentation issues. Please check if iCloud has been turned on to synchronize your files and notebooks (☁️ will be shown below if it has been turned on); then select iCloud from the more in the bottom left corner of the main interface, enter the synchronization interface, see if there are any errors, if there are errors, try to turn off the corresponding iCloud switch, try again after 30 seconds; if it shows that it is downloading, then please wait patiently: make sure that the connection is clear to WI-FI, stay in the iCloud synchronization interface, make sure that the device is always on, turn on the power charger; you can also try to restart the device or restore the network settings, we are optimizing the synchronization function, we expect the version 3.7~3.8 will be improved, in addition, the handoff function can be transferred, airdrop can also be tried~
MarginNote-Bryan
