Hi, I’ve gone back to 3.6 because 3.7 either does not import anything when importing a mmap file or it crashes (the latter if you use the menu, the former if you click on Import… in the document).
This is a dealbreaker for me as it’s integral to my workflow so I won’t be upgrading until this works. However I have updated my iPad so I am worried that files will not be compatible. If I don’t use handwriting on iPad, will I be ok for now?
Thanks,
