About discount of Marginnote 3 and 4 on MacOS
I have bought 3 in iPad for 2 years and I upgrade it to 4 recently. If I wanna buy 4 in macOS, what should I do? I am used to manage it with home-brew so I should use dmg version. I have got my education discount for marginnote 3 Mac version.
The dmg version will be upgraded in the near future, please wait for a while, it is already being tested
Thanks. So I shouldn’t use the discount code I received yesterday thought it is only valid for 48 hours? I just wait until the dmg version for marginnote 4 and ask for another educational discount. However, I have read that there is some policy to upgrade my pro to max or some other things, is that suitable for me?
If you want to present on all major platforms max version, using education offer is not appropriate, education offer is only applicable to Mac
I know. But if I want to use 4, if I buy 3 now with educational discount, can I upgrade it to 4 for free on Mac.
It is recommended that you wait for the online consideration, and it is more recommended to use the App Store version for multiple devices. After the discount code expires, you can reapply
So if I wanted to use MN4 on all my devices, the edu discount would not be useful, right?
Thanks
At present, the latest progress, education offers can also use the advanced version of present on all major platforms, but the way is more complex than the appstore version
So if i want to use Mac and iPad together, can i wait for the student discount?
can wait
Is your problem solved?
