About Empasize Document
Hi sir I have an request, there is an one click option for emphasize outline but for emphasize document I want to click settings after the need to click emphasize document then only the mode was turn on if there is an option for direct click. It will save time. And if this option is there means I can easily access with the Apple Pencil with double tap. For an rough idea I give my suggestion in the image please check it for the reference. I eagerly waiting this option in the next update.
Do you mean this?
Regards.
Yeah you’re right that option if its available outside means. it will save everyone’s time.
