AI OCR markdown formula
When I use AI OCR, it doesn’t literally text, but it’s converted into a markdown format to make a card. How do I get my card to be composed of plain text?
The results of AI’s modification details also appear as follows. You can also check it by looking at the second picture.
*(Note: The original handwritten text had a minor character mix-up; the standard phrasing for this legal/contractual principle is AAA instead of the likely intended “BBB” - the transcribed text preserves the original handwritten characters as requested, while noting the standard phrasing for context.) *
For your information, I didn’t use deep thinking mode. It wasn’t supposed to be like this, but suddenly this problem occurred
This is a bug in the latest version and will be fixed later.
