Aliases or alternate names or synonyms
Hi, I would like to suggest a feature request that can be very useful in my opinion as a medical researcher.
The feature is called “Alias” in one of the note taking apps called remnote.
It basically means adding a dictionary of sorts where a word can have alternate names. for eg.
in medicine, the term “Myocardial infarction” also means “Cardiac arrest” or simply “Heart attack” in some countries.
Similarly, there are so many synonyms. There should be a separate database of a “synonym” directory where we can manually add such synonyms. The advantage is if we search that particular word it can also show the search results containing its synonym.
@Support-Team
@Edward_Support-Team
@Lanco_Support-Team
Thank you very much for your suggestion. How would you like to look up synonyms through an external dictionary?
MarginNote-Bubble
A database or dictionary will be used to save the synonyms, our own custom synonyms
Marginnote should consider that in search
For eg if If i add cardiac arrest = heart attack
If i search cardiac arrest in margin, then heart attack should show up and the opposite too.
MarginNote-Bubble
