An extremely quick and easy way for search function (SEARCH BUTTON BESIDE RESEARCH BUTTON )👈
Currently if we want to search something in documents we have to-
click search button—>type or copy (if long)—>paste.
This is time consuming and hard to do for few times. (Eg-Anterior tympanic artery. It contains three words. Therefore lot of time consuming for terms like this)
Therefore my suggestion is to introduce SEARCH BUTTON BESIDE RESEARCH BUTTON for both document screen and mind map screen.
(This is to find other sources of a word/term.)
Actually you don't need to copy/type what you found online - you can just simply select them and then drag them to the existing card (as a comment), or drag to somewhere empty (to create a new card). This will make your work more efficiently I hope.
For searching the words, adding this button is kinda similar with the workflow you currently have - and we cannot assign an official website for the dictionary, so you still need to google - basically no difference.
MarginNote-QSD
I think you haven’t read my request correctly/fully.
I haven’t mentioned about internet searching or dictionary.
This is about a shortcut to search across all documents in a study note.
@Support-Team @QSD_Support-Team @Edward_Support-Team @Relight_Support-Team
Sorry about the misunderstanding.
Yes I think this is a very useful function, thank you for your suggestion.
I have forward this to our developer team.
Any update? It’s been more than 6 months.
This would be an extremely time saving feature.
The will power for typing always diminish with me when i have to use the search function frequently.
I am requesting only this shortcut for searching within all documents.
Hello, you can try to use multiple open windows to achieve it ~
MarginNote-Relight
Use multiple open windows?
My request is not about your answer.
Why can’t you read my request correctly?:downcast_face_with_sweat::cry:
Oh, is it easier to search? This has been mentioned by a few people, and is still under consideration ~ good suggestion ~
MarginNote-Relight
No need for consideration. Have you been considering it for over 7 months?
As there is a research shortcut, there should be a search shortcut.
This would be extremely useful for all users.
It d be the best feature for mind map hand writing.
Because after we added captures on mind map, we automatically create link framework that can be opened with this feature (if @Support-Team considers) without needing to write again anything
(wtiting something that already on screen is so wasted time and willpower process)
We Need Action, any process ?
I m wondering what are u doing for MN as a team now ? What makes u so freeze
They don’t care. :downcast_face_with_sweat: I can’t imagine what they are doing all the time. Fixing bugs?
May be developing MN is their part time job.
We need this
