Annotation BUG 🕷
This bug happens so many Times. Every 5-10 minutes !!!
Only solution is restart the app
@Sushi_Support-Team
@Support-Team
Can confirm. I have similar issues where the mindmap simply disappears, or the handwriting starts to stutter or simply disappears as well. I have to restart the app every 30 minutes approximately.
I will try to make a recording when this happens.
On a more personal note; I don’t need features, I need this app to work when I am learning for exam.
Hello, do you write by hand all the time? Do you need to write frequently in the card editor?
MarginNote-Relight
Yes write a lot with using card editor.
After fade problem happens, I can’t use or write anything that space also
Hello, we will try, once the problem can be reproduced, it will enter the repair link, our development technicians can find the fault code and repair through reproduction, thank you very much for providing feedback
MarginNote-Relight
