Assistive excerpt is capturing text blocks, headers, etc. as images/bitmaps, why?
When using Assistive Excerpt, when I double-tap/click a block that is purely text, it makes a card that is a bitmap graphic of the text, rather than a text card. Is there a way to have Assistive Expert make text-based cards?
Bitmaps of text are inefficient and useless to me.
And yes, the original file is text.
I found if I have Convert Rect Images to Text enabled that it does make cards the way I want them. My worry is that it’s still storing a bitmap somewhere and that is inefficient.
Currently not possible, you can set text priority in more after multiple selections
Well, that is most unfortunate and with the inefficiencies already present in cloud storage and MN, this just makes the feature useless. I do understand how it can help some users, and I guess I’ll use it exclusively for images that I need to excerpt (rare).
Please consider text-only auto excerpting with Assistive Excerpt feature. Thank you.
