Let’s say I’m adding some cards as sub-items under ‘A’. If the ‘Automatic copying between ‘A’ and B’ feature is enabled, all the cards that I add to ‘A’ will also be copied to ‘B’.
it makes the copy paste issue solved and let user better interface.
Scenario example. For examle u are adding some cards in the main mind map; with that speciality u will see them under another mind map as synchronisedly
Thats will be huge improvment after the Aİ speciality.
