AUTO INSERTIONN POSITION settings
İn Study Mode User CANT change where the position of node should be
İn Document Mode User CAN change where the position of node should be
WHY CAN NOT we CHANGE BOTH ?
@Relight_Support-Team
i found solution myself.
aouto insertion was closed because i was using in CHİLD mind map focused
in other words the app let the change settings when you are only working in MAİN mind map.
Today, I encountered the same challenge. Based on @isaatalay42 sharing the above insight, I now understand that auto-insertion is not available in child maps, and that this behavior is not a bug.
However, the design decision to prevent auto-insertion in child maps brings some significant limitations.
For example, I would prefer to use Child Maps to organize certain excerpts but I can’t do so because I also need to use auto-insertion. So in those cases, I have to use the main map even though child maps would be more suitable for organizing the contents I’m working with.
If it is technically feasible, I would kindly ask the MarginNote team to allow auto-insertion of excerpts in child maps in a future release.
