I keep having massive problems with the horizontal bar (in the MacOS version of MN#), and I’m sure this can be fixed.
In short, the bar is way to narrow! Whenever I’m trying to use it to move to another section of a document (e.g., a document I’m looking at with horizontal ), the cursor slips off the bar, and slips into annotating the document! This is incredibly frustrating, and makes it hard to carry out what should a very simple task: center the document to where I want to view it.
I’m begging you… Please, PLEASE fix this so that we can have normal sized horizontal bars, that allow users to shift and center documents as they wish!
Thank you!!!
