Bookmarks for audio / video
it would be useful if positions in audios / videos could be bookmarked.
These bookmarks should ideally have full sync capabilities via iCloud. Same for PDF bookmarks.
Thank you for your feedback. What form do you want this function to take? What is the reason that the current excerpt function cannot meet your needs?
Hi @mono
well, excerpts and bookmarks serve a different purpose.
I use excerpts to capture the sections I want to review later.
The purpose of a bookmark, on the other hand, is to be able to continue where I left off OR to return to specific sections. For example, I might add a bookmark at the start of each chapter. Using excerpts for this would not be a clean solution.
Ideally, the bookmarks would be stored along with the document so that they are accessible in both document mode and study mode.
