I am encountering a bug, which I would kindly ask you to take a closer look at. It is a real obstacle for my usage of MarginNote.
I will walk you throw the steps to reproduce the bug with some screenshots.
Step 1) Create a topic with some tags, copy it as a reference and paste it.
Step2) Filter for one of the tags via the outline
You will see that the original topic and the referenced topic are shown in the outline after filtering, which is correct behavior.
Step 3) Remove all tags from the referenced topic
When the tags are removed from the referenced topic, they are also removed from the original topic, which is correct behavior.
Step 4) Filter the outline for one of the tags
BUG: Even though there are no more tags, when filtering the outline for one of the tags that were previously on the topics, MarginNote thinks that the reference topic still has this tag. Although the tags are not displayed on any of the topics, somehow they remain present on the referenced topic (but not the original one), when filtering the outline.
This is a big problem, because I can no longer filter maps reliably based on tags, as soon as there are referenced topics.
I would truly appreciate it, if you could make it a priority to fix this bug in one of the upcoming maintenance releases.
Thanks in advance and keep up the good work. I heavily rely on MarginNote for my personal knowledge management and have no plans to change that.
