Card size in mindmap
How to increase the card size in mind map to write more information in that card.
If we drag the corner of the card, it increases the size of the content of that card.
What i wish to achieve is increase the card size without increasing the content inside it so that I have more space to write into.
For now, I don't think you could. Nevertheless, you are not limited vertically.
If you have updated to MarginNote 3.7, you could just turn your handwritting on the mindmap to a card, but the size of handwriting may shrink.
MarginNote-Sushi
Can you please consider this a feature request to expand horizontally as well in a card
You are able to write as you want, if they have given zooming ability for image excerpts/cards. (As like in other pdf annotators.)
writing ability without zooming ability is useless. I have raised the request few months ago and they should have given the feature in this recent update.
I will raise this issue to the development team again, but I am unsure whether and when this problem will be fixed.
MarginNote-Sushi
