ChatPDF in Marginnote
I just found that ChatPDF has just been added to LiquidText. It’s a much-needed feature, and I’m contemplating whether I should switch to LiquidText for its feature.
I wonder if Marginnote Team also has a plan for integrating ChatPDF to their program.
The paid version of ChatGPT allows you to converse with PDFs. It restricts it answers to the PDF. I’ve not tried it with multiple PDFs but it at least can streamline the process of working with literature.
Chances are, like LT, MarginNote’s implementation of AI integration won’t match my needs precisely, I find paying for OpenAI’s model to be favorable than LT’s required sub + token cost and likely anything MN is going to do as well.
It’s really good.
Can anybody tell what dies this answer of the super team mean?
It means it’s a good suggestion and we will consider it.
You can try
Not very convenient but works with built in chatgpt 3.5
Please make it English version
