Continue "continous excerpts"?
is it possible to continoue “continous excerpts” once completed excerpting for the card? Like the option to cointinoue marking pieces of the text and it getts auto-added as comments to the card, for example if youd forgott something.Thanks for the Help!
Yes, MN4 offers a “Continuous Excerpt” feature. When you are making an excerpt, a black menu bar will pop up. Click on the multi-grid icon, and all subsequent excerpts will be integrated into a single card until you click pause.
If i pause the continouse excerpt, is it possible to continoue afterwards on the same card? Or do i have to make a new card and merge both cards in an extra step?
After you pause the continuous excerpt, you can long-press and drag the new excerpt to move it into the existing one.
