The problem: Copy by Reference has stopped working starting today, the last time the function was still working is yesterday.
There is still a success prompt after trigger by either context menu button or shortcut.
I checked the Clipboard Manager and can confirm only Copy by Reference is indeed not working, whereas Copy by Clone is working fine.
What I’m trying to achieve:
Copy the URL of MN3 note in Mindmap.
What I’ve tried, by order:
- Restarted MN3
- Restarted computer
- Disabled all extensions
- Clear Temp Storage
- Database Defragmentation
- Uninstall & Install MN3 again
Please help look into this issue and suggest a solution or a workaround.
Troubleshooting information
OS: macOS Big Sur 11.4 Apple Silicon
MN3: 3.7.16 (3.7.16003)
Edu Version
