"Copy Note URL" into popup menu
I often use this command to link MN to other applications e.g. to Obsidian or Craft. To use this it is cumbersome to edit the note, click on the … menu, select this and close the note again (see here)
Copy Note URL is available under the edit menu with a note selected. It’s Command-Shift-C (or perhaps I’ve set it up to be that). You could bind it however you’d like of course.
:blush: didn‘t look there, thank you!
But as I am working mostly on my iPad (without keyboard) another option would be useful.
Agreed, this is something I also do a lot however I don’t find myself often using the iPad to work cross application so I didn’t really notice its poor lack of support for this feature.
@Support-Team please bring the Copy Item URL functionality closer to the surface on the iPad?
