I want to automate my homework tests making by writing a script, in this script, I copy the note with the picture of the problem and the text of the answer. But when I paste it, it recognized text and text. I can’t find any way to change it in settings or anywhere else. Ple help me with that.
I am not sure I followed you on 'recognise image as text' part, could you elaborate this?
Any screenshot or screen recording demonstration would be appreciated.
MarginNote-QSD
I have a picture and a text in the note. When i copy the note using ctrl+c, i get only text after ctrl+v(like i used text recognition on the picture).
I see. It is not the usual case, the image should be exactly an image - at least from my side.
Did you turn on auto OCR in excerpt setting(next to the lasso tool)? Turn it off and then it would work I hope.
MarginNote-QSD
It’s off. So please help me with this problem.
Hello, as you copied the card directly in MarginNote3, the image itself was not copied directly for performance requirements, we will explore this further ~ this is indeed an excellent use case.
MarginNote-Relight
Waiting, this automation is supposed to save a lot of time for me.
Anything??
