Nils
March 21, 2023, 12:29pm
1
Problem
When trying to create a link between two notes in the MindMap, it only copies the text from the linked note into the other note.
Expected behaviour
It should create an arrow that can be annotated:
Problem solving
I have desinstalled all extensions, turned off Title Link and set Child Mindmaps to “Drag notes as two-way link”.
Version
Version 3.7.24 (3.7.24006) on MacOS 13.3
Nils
March 23, 2023, 6:29pm
2
It does work as expected on iPad if that helps, @Support-Team . I’m just trying to add new links on my documents as I used to. Any simple fix, setting I need to change?
Nils
March 29, 2023, 4:05pm
3
FYI: Re-indexing the database did solve the problem. Would have liked a quick reply though.
Hi @Nils & @Support-Team ,
I have the same problem. How exactly did you “re-index the database”? I only see the option for “database defragmentation” and it did not help.
Thank you!
jakob0b
November 14, 2025, 11:23am
5
Hello i have the same problem, what do you mean by “Re-indexing the database”?
jakob0b
November 19, 2025, 1:37pm
6
I really need help with this problem, linking doesnt work for me on macos
jakob0b
November 27, 2025, 1:26pm
7
@Support-Team is there any solution for this?
