Critical: Text scrambling issue when selecting content (Cmd/Ctrl+A) in Notes and Mindmap
Description: Whenever I select text within a text box in a document or on a card in the Mindmap using “Select All” (Ctrl+A) or the mouse, the text formatting breaks completely. The characters become scrambled, or the layout/line order is corrupted, making it impossible to read or copy the content correctly.
Steps to Reproduce:
  1. Open a PDF document in MarginNote.
  2. Create a note or a text-based card.
  3. Use the mouse or the shortcut (Ctrl+A / Cmd+A) to select the entire text content.
  4. Observe that the text display immediately corrupts/rearranges itself.
Expected Behavior: The text should remain formatted as it is, maintaining its line breaks and logical order when selected.
Actual Behavior: The text jumps into a chaotic order, suggesting an issue with the underlying rich-text rendering or the OCR/selection-parser.
Turned off AutoCorrect Spelling in Menu Bar - Edit - Spelling & Grammar
The Setting turns on automatically every time.
Is the corresponding function in the system turned off?
this problem occurs also when Type Spelling is turned off for the whole System
What is the system version? Here, I tested turning off the system and the automatic spell correction in the software, and no issues occurred.
