Customizable double tap action
Hi there. I would just like to request that MarginNote add the ability to customize the double tap action on the Apple Pencil. Currently, if you squeeze the pencil, a little menu pops up and you can choose what squeeze does. But for double tap, it defaults to switch eraser and you can’t change it. Please could the same menu be added for double tap as there is for squeeze, which would let you choose what it does.
Thank you for your feedback. We will analyze this requirement.
