Delete pdf without deleting cards
Is it possible to delete an annotated pdf without deleting the cards created from it that have been organized into a mindmap? I don’t see a Delete option when I click the “…” of the pdf in study mode.
Thanks.
can directly delete the PDF without affecting cards and notes; simply re-import the original PDF when needed (it must be the same PDF)
Thank you for the quick and helpful clarification! I appreciate you confirming that the PDF can be deleted without affecting the cards and notes, and that it can be re-imported if needed. That really helps.
