I have double tap set to switch to the last used tool. In MarginNote this does not behave as expected, because it switches between annotation and highlighting - not to the last tool that was used. Please can this be corrected so that it switches to the last tool used?
Yes, we didn’t implement this feature as the apple preference implied, just use this setting slot.
Thanks for the reply, Min. Can you please consider changing it to be the way it works in Apple Notes? I frequently need to switch between Select and Highlight, for example.
Plus one on this request.
What I’m lacking is the ability to switch between “free flow” pencil and “straight line” pencil. If this could be accomplished with the double tap gesture that would be awesome.
