Hey there !
I’ve puchased marginnote 3 with an edu discount on my imac and activated it , can i use the same activation code to install a copy of the sofware even on my macbook ?
Please help because i’m not shure to have anderstood right the use of it on multiple machines
Thanks a lot
Yes, it can be used on two devices.
How do I install On 2nd device ?
Then how do I share between devices?
you could set synchronisation using icloud (both services need to use thesame icloud account)
I am willing to pay for 2nd MN APP - but I still cannot find a way to access the files created on device1 in device 2. I share on drive, I email, I send over the url = how??? Can I run the notebook on the second device>???
Thanks
- you could download app from here Store
in other thread you mentioned about your’s son device
if you use the same apple ID on both devices after you do setup of icloud it’s should automatically sync
on ios you could easily enable icloud sync, on mac probably the same way
Unfortunately the company doesn’t implement yet any sort of airdrop:( As far as I know, i am not related to it
