I found there is an annoying page jumping error where there are multiple documents opened. Here is how it goes:
In the “Study” mode, open two documents: A.pdf, B.pdf.
Split A.pdf to two views, and turn the top view to page X, the bottom view to page Y.
Switch the top view to the other document, B.pdf.
When switch the top view to A.pdf, the page will be jumped to page Y (as the bottom view), instead of the original page X.
This is very annoying because it requires relocate to the original page number.
Could you please check the issue and fix it?
Thanks very much
