What does this actually do, please? I have tried the various PDF export options and I can’t see what this one is.
The ability to export the notes annotated on the right side of the document is not currently supported. You can try exporting notes as Word, which will give you a note outline.
Hi, any update on this please? I’m keen to understand what the ‘export right margin’ in my screen shot does or whether I’ve understood you correctly that it doesn’t do anything?
