It would be great use MN with two monitors, one with the the PDF and another with the mindmap
I second this
Hello.
I use a 3 external monitor setup. Just for academic use, not a gamer. Nevertheless, I know I am a little bit extreme, but dual external monitors are getting common, and I think to use one external is nearly standard. It helps a lot for programs like MarginNote, where you have different kind of content.
By the way, I post in that image some problems I have with the excerpts window: it does not link to document, and closing it (which happens every time I select a node) means resetting its arrangement, forcing to re-zoom. And I see that after making a summary node, seems I can’t make another one in the same row… But well, sorry, that are other problems.
Hello, will this button solve the problem? I don’t have an extra monitor to reproduce what you describe, so I’m worried that I don’t understand exactly what happend.
Regards.
I do not want to sound exaggerated, but I love you and all your descendants … all gods bless you for that answer. Have a good life
Not really, Edward. The effect I have with that bottom is a quite aleatory displacement.
Thank you for your answer and sorry I come so late back to it. In the excerpts window, a click on a node does not lead to the original text, as I expected. And when I click one, the excerpts windows closes, so I have to reset all the arrangement. It would be great to have something like a memory of how the windows are set up. But well, this could maybe be solved when we can use other monitors.
