Feature Request : Relocate position
If you edited the PDF outline externally, it would be useful to position the excerpt.
If you modify the outline of the pdf currently working on marginnote with an external tool
I think it can be useful when the location is all misaligned.
Apart from that, you just accidentally set the auto-add option incorrectly for the first time.
I worked hard, There are cases of being in vain T_T
Currently MarginNote3 does not support catalog editing, you can check the introduction of catalog making and edit the outline of the document
https://forum.marginnote.com/t/feature-request-edit-table-of-contents/840/13?u=lanco_support-team
MarginNote-Bubble
