Is there any kind of Find / Replace tool in MarginNote?
Also, is there any way to change smart quotes to straight quotes in MaginNote?
If so, please advise.
If not, @marginnote please consider creating these options !
Thanks.
Thanks.
I’ve found that excerpts from some PDFs result in text with double spaces between words. I can fix these manually, of course, but if MN could detect these automatically and fix, or if there was a search and replace where I could replace “ “ with “ “ that would be superb.
I’m truly impressed with MN and am using it (almost all day) every day during my studies. Thank you to the developer/s.
@stuartro The new ocr pro may suit your needs. Auto correct online and change the offline ocr settings into ‘Always’ will reload the book image to correct spaces.
About Find/Replace, since MN is not an typewriter, this function will need 3rd-party scripting when MN open Data API in 4.0. Sorry for your bad experience. I don’t know whether your case could be pre-avoided by OCR correct.
Sincerely,
