It is not enough to view documents and mind maps at the same time, rather than a large wide monitor.
It would be much easier if the window was separated and managed separately. Especially in an environment with multiple monitors!
I think it would make more sense to âfloatâ the document window since it already seems as if it is hovering over the mind map. By UX definitions, floating windows always stay on top, they donât go behind other windows unless there are conflicting floating windows. I would love to âdetachâ the document view in research mode from the mind map precisely for that multi-monitor experience. I certainly wouldnât make this a default, however, and would always want a way to reattach it as it currently is.
As to whether either of these windows âfloatsâ with an âalways keep X window on topâ option then that would be great as well, particularly if X window was the mind map or the document, my choice.
This can be done, was mentioned on the forum but not very obvious. Just open a new window so you have two, move one window to the other monitor and open the same âstudyâ in both, one with the mindmap one, with the document. Theyâre automatically linked.
Thanks @ascii78 I do not know how I missed that menu item. Iâm sure I mustâve noticed it once when I first got MN3 but I obviously forgot about it. Cheers.
Using multiple windows open Is also inefficient
In particular, it is unfortunate that the usability becomes somewhat complicated when used with Auto locate.
And if you use the shortcut key, it can be twisted together T_T
âdetachâ would be more precise . Itâs close to what Iâm trying to say
Thank you for your suggestion.
Floating does seem to be a good alternative.
And as mentioned above (p.s. many thanks to @ascii78), yes we do have a not-so-mature floating mechanism.
We will be working on to enhance it.
MarginNote-QSD
