Highlight Menu and Drawing Toolbar
Hello There,
I’m using the iPad version of Marginnote 3 and I’m so happy with the functionallities. I have 2 questions:
  1. Is there any way to configure the Highlight Menu and Card Menu? I want the “Focus” option to be one of the first on the list.
  2. Is there any way to configure the Handwrite Toolbar, to be above the window? When I’m writting, sometimes my hand touches one tool by accident.
Thank you!
As of now, it’s not possible. You’ll probably have to wait for MarginNote 4.
However, there are some workarounds. For (1) you could use keyboard shortcuts, and for (2), try to use your iPad in landscape mode.
Kevin
Hello Kevin, thank you for the answer. Is there any plans for the new Marginnote 4?
And now I’m with another question: is there any way to export one card to other applications (in my case, goodnotes). If there is not, is there any way to export a card to an image?
Thank you again
