Ü
I am experiencing an issue while using Recall Mode in MarginNote 4. I use the highlighter tool to mark text, and when Recall Mode is enabled, I expect the hidden sections to be revealed when I tap on them. However, when the highlighter tool is selected, tapping on the hidden area creates a new highlight instead of revealing the hidden content.
My expectation is that even with the highlighter tool selected, tapping on the hidden sections should reveal them. Currently, this seems to only work in the cursor (pointer) mode, which reduces my workflow efficiency.
Is there a solution or a workaround for this behavior? Is there any setting that allows the highlighter tool to reveal hidden areas in Recall Mode?
I would greatly appreciate any help.
Thank you![quote=“Tuna, post:1, topic:9926, full:true”]
Ü
Thank you!
[/quote]
