How do I completely remove Margin Note 4 from MacOs?
I am having issues on syncing MN4 using icloud and I believe a complete reinstall on macos and download form cloud will solve that.
How can I remove all MN4 files, including folders on library etc?
Additionally, how do I do the same on iPad? I am having issues with sync there too
Hi, I have paid the MarginNote MAX and cannot use it because my library is not properly synced with MN 3. How do I perform above steps?
Thank you!
I have managed to reset MN4 on Ipad by reinstalling it. With a fresh installation, I managed to successfully import from MN3. I hope I get some support for next issues I face with margin note…
