How do links work in MN3
How is the functionality of “links” supposed to work?! In Liquidtext they allow you to jump from one part of a document to another (or to part of another document provided it is in the same project) but I can’t get them to work at all in MN3…
Any tips?
Jim
Linking as far as I know, just creates a connection between one note and another… and also “merges” the two notes. If you click link, you can drag the 4-directional cursor to another note, and you’ll see. if a note is merged you’ll find a button you can double tap to jump between notes (and therefore sections in the pdf)
Much of this blog would be unnecessary if there was a better resource on how to use MarginNotes
