Hi All
The default colour for the mind map connecting lines becomes difficult to see if you connect the cards/nodes using the Apple Pencil. Does anyone know if this can be customised?
Trawled through all the settings but can’t find it anywhere or at least not obs to me.
Also, is it possible to customise the position of the cards/nodes in the mind map, rather than MN4 auto positioning them?
Thanks
