Purchased margin note (regrettably) for the Mac and using on a MacBook Pro.
Is it not possible to delete nodes using the delete key on the keyboard ? or am I missing something here?
Instead the only way to delete is to mouse click the trash button on the pop up context menu ?
It is possible to copy and paste using keyboard shortcuts but the delete key has no effect, why is this not considered important ?
This seems like the most basic function for any software but for some reason the margin note team does not consider this important ?
If this is the case it is truly baffling and unacceptable. I spent 8500rs (A large amount in my country) and seriously regretting the purchase. @Support-Team
