How to export outline on MN4?
I cannot seem to find an option to export the Outline in MN4. Can someone point me to the right direction?
Hi, I have the same issue. Did you find a solution to the problem by any chance?
You can export a card outline by following the steps demonstrated in this tutorial video. If you require exporting outlines in other formats please describe your specific needs in detail.
Best regards,
MarginNote Support Team
Uploading: 8c86d4032ecbac8a08f1e1fe06c9be3f.mp4…
@Adeline
Hi - your link doesn’t work. Would you mind reposting?
I’m sorry but it doesn’t work, can you re-upload the video please?
sorry I’ll instead depict the process with screenshots
