Hi guys, I am experiencing synching issues between devices (iPad and MacBook). In the past couple of months, this issue has appeared more frequently, and it really slows me down when working. I was wondering how can I force synching in MG3? From what I know “Manual Synch” is the only option available. However, that option doesn’t seem to work right away, and you still have to wait until MG3 kind of decides to synch up. This has also happened with very little content so the amount of information pending to be synched wasn’t really the issue. Thank you!
Hello, you can try to turn off MarginNote’s iCloud in the system settings and then turn it on about 30 seconds later
Right, understood. Thanks!
