I use MN4 iPad and Mac
as you see in screenshot
when i highlight with Apple Pencil in iPad Air 13, fade effect is little. so no problem.
but when i highlight with Mouse in Mac mini M1, fade effect is so big. so it doesn’t look good.
How can i delete fade effect when i highlight with Mouse in Mac mini?
You can use the mouse just like you use a pen on an iPad. Adjust the parameters of the pen in the settings of the pen disk or erase it with an eraser
I want No fade effect when I highlight text using Mouse in MN4 Mac Ver.
Because when we highlight text using Mouse in MN4 Mac ver., we can Not click Strong or Weak. On the contrary, we Can write Strong or Weak using Apple Pencil in MN4 iPad ver.
so I don’t have problem in MN4 iPad Ver.
I try to find an setting that OFF highlight Fade Effect in MN4 Mac Ver., there is Not.
It is Not the erase and re-highlight solving problem.
Every time I highlight using Mouse in MN4 Mac Ver., the fade effect is So strong.
When I using Apple Pencil in MN4 iPad Ver, No problem
There is Not an Setting that OFF the highlight Fade Effect in MN4 Mac Ver.
I want to OFF fade effect when I highlight using Mouse in MN4 Mac Ver.
I hope that developers consider an Setting that OFF the highlight Fade Effect in MN4 Mac Ver.
Are you referring to turning off the handwriting on top of the text function?
I am writing about ‘Always’ Fade-out effect is ‘On’ problem when I highlight a text with Mouse in MN4 Mac version app.
I want No fade-out effect when I highlight a text using Mouse in MN4 Mac Ver.
Because when we highlight a text using Mouse in MN4 Mac ver., we can Not click Strongly or Weakly. On the contrary, we Can write Strongly or Weakly using Apple Pencil in MN4 iPad ver.
Fade-out effect is different density of highlight color
So I suggest that like ‘Straight Line’ option(‘OFF’, ‘Auto’, ‘Always’) that already existed in MN4 Pen and Highlighter option, developers make ‘Fade-out effect’ option(‘OFF’, ‘Always’) in MN4 Mac version highlighter. or at least developers make ‘Fade-out effect’ ‘OFF’ when highlight a text with Mouse in MN4 Mac ver.
Understand your needs, will feedback
