Hi. I created a notebook and added several files to it. There is a text box there now that shows the name of the file. However, if I click on it, nothing happens. How can I read the file and/or begin studying it?
Hello, are you in learning mode? In learning mode, if you need to read a document, you need to open the document view. What you should see should be the note cards in the Brain Map view.
Hi. I was in study mode. I couldn’t fix it. I deleted the iPad app and then reinstalled it. They eventually became visible. I had tried to do the double tap to see them (like in the iPhone), but that wasn’t working.
Thank you for your reply, would you be able to upload some screenshots or videos describing it in detail? That way I can help you better.
