Hi, is there a way to remove a note from a Mindmap (without deleting it in the document)?
BTW, MN is awesome on so many levels, wow, thank you for such great taste in designing something so very functional for active reading!
Hi there, thanks for the comment and here is the how-to regarding your question:
MarginNote
Super happy to learn there’s a solution, thanks!
Yeah, this feature is well hidden but it is there.
That 3-step method works for 1 note and >1.
If you have multiple notes to remove, might as well skip Step 1 aka use the Select button first.
