How to remove from a mindmap without removing from the review cards?
Hello, I’ve been using marginnote more for studying my exams. I occasionally temporarily add my cards to the mindmap to merge notes together but I don’t want them to clutter my mindmaps.
Is there a better way to add notes into my cards or a way to remove cards from the mindmap without it removing the card from my review cards too?
Selecting the remove from mindmap removes it from both.
I understand your needs. I think you can try putting the cards you want to discard into a sub-mind map, so that you won’t see them.
I’d still see the child in the main mind map tho which adds to the clutter
