Hi there,
I purchased MarginNote 3 on my iPad, and now I moved to use Macbook, will be no longer using iPad. I used same apple ID downloaded Marginnote 3, but when I pressed restore purchase, it doesn’t work.
Can someone please help?
Hi there,
We are very sorry, but you will need to purchase Marginnote again for the MacOS platform.
If you are a student then there is also a 40% discount.
Also, you could still use the iPad version of Marginnote, and just use the MacOS Marginnote as a free browser to review your notes & mindmaps.
MarginNote-QSD
Will iPad user get a discount for repurchase on MacOS?
thanks.
Unfortunately no...
MarginNote-QSD
