How to Swap Document and Mind Map Positions in MarginNote 5
Hello MarginNote Support Team,
I’m using MarginNote 5 on my iPhone Duo with the screen fully unfolded.
Currently, the document appears on the left side of the screen, while the mind map is displayed on the right.
I’d like to know if there’s a way to swap their positions so that the document appears on the right and the mind map on the left.
Is there a setting or gesture that allows me to switch between these two layouts?
I’ve attached a screenshot of my current layout for reference.
I’d appreciate your guidance.
Thank you!
Hi Chacy, thanks for reaching out! Please try updating MarginNote 5 to the latest version and check whether you can now place the mind map on the left and the document on the right. If you’re still unable to do so, please let us know your app version so we can help investigate further.
