How to undo title only?
How do I undo the title only in the outline, the undo button doesn’t work.
It seems to be some kind of formatting that makes all text in CAPS, I want to resume normal text.
I deleted this document and the same formatting still remains, please help.
About CAPS,try to double click the caps button.
About Title only, it is a toggle button. Undo is only used to correct type errors which do not contains toggle changes at present.
Oh ok thanks for the solution.
