Hello.
I notice that I could use markdown in the MacOS version but not in the iPad version of the app. In the Mac app, there is a markdown button when I edit cards but this isn’t available on the iPad.
Is there a way to access markdown on the iPad?
Hello.
Yes, after you click to edit the card, there will be Markdown icons.
Thank you for the reply but I can’t seem to find these icons on the iPad. I can find them on MacOS pretty easily but it doesn’t appear on the iPad.
These are what I see on the iPad
On MacOS, I can see this
But this doesn’t appear on the iPadOS version.
Hello, I’ve figured it out! the hide keyboard accessory was on for some reason. I don’t remember turning it on but turning off fixed it.
Thank you very much for the help
