i am using MN4 on ipad only and have upgraded from MN3 and purchased MN4 max, I am directed to keep MN3 copy for verification purpose, which i later upgraded to max (lifetime) purchase as this has been my study buddy.
now the problem is i have run out of my icloud storage. because i have to keep both MN3 and MN4. becauise of which my sync has been diabled in MN4
my i cloud storage lists 3 folders namely
Marginstudy (MN4 icon) = 28.5GB
Easy (MN3 icon) + 9.6GB
Marginnote 3 = 17.6GB
my total storage in icloud plan is 50 GB … u know there is some bug as above mentioned folders are larger than total storage plan. pereviously this was just a visual thing till MN3 was alone, but now its eaten through my storage space. which indicates i have over 96% documents among my storage files on icloud.
how do i fix it?
i have icloud sttings enabled for MN3. should i disable those? and should i delete both the folders namely “easy” and ”marginnote 3” to clear up space? by doing so do i risk losing some of my files? i transfered my data fro MN3 to MN4 using the options.
thanks for the response, i just plan to using MN4 but i was advised to keep its copy instaalled for verification purposes even after upgrading to MN4 by the prompt that i got while availaing the upgrade discount(MN 4 plus was a free upgrade).
so i think i cant remove the app including all the data.
I have disabled icloud option fro MN3 in icloud.
Now i want to pull the trigger and delete “marginnote 3” and “easy” folder in icloud. but i am unfimilar with the process of backing up from icloud. So even if i back it up, there wont be anyway to put it back up in cloud. wierd apple ecosystem.
im gonna start with marginnote 3 deletion, what do you suggest regarding “easy” folder
If you already have all the data you need in mn4 and are not going to be using mn3 at all, then it should be fine to just delete all documents and notebooks from within mn3.
