Import audio file?
I know how to import a video, but I can’t seem to import an audio file into a project. Is there a way to do this?
Sorry for the late reply.
To add an audio, firstly find your wanted card, then click card-edit button, then you can see the audio button down the window where you can record or import MP3 files.
MarginNote-QSD
Thanks very much. I looked everywhere but there!
Is there a way to delete the audio file once it’s added to the note?
There is an 'edit comment' option down the note editor window where you can delete every section of your note including the audio.
MarginNote-QSD
Hello, besides mp3, are there plans to add support for uncompressed audio (aiff, wav) and the m4a format? Thank you and best regards, Robert
Hello, could you please share more details about why you need files in these formats? The clearer our understanding is, the better we can improve our product for you.
Thanks for asking!
Of course I can also use the mp3 format, it’s not a real problem.
With a large number of audio files, it only means more effort for me.
The reason is that I have been using exclusively m4a or uncompressed audio formats for years, so that when inserting an audio file in MarginNote, the previous step of the conversion is always added.
